racetronix fuel pump
Old 07-15-2012, 04:43 PM
spiro27's Avatar
Smile racetronix fuel pump
my 01 trans am has 226-234 cam tfs 215 heads 1.7 yellateras long tbe headders 1/78 and 42lb racetrnics injectors fast 92 intake and tb . just finished putting it all together ans was tols i should do fuel pump before tunning. looking at the ractronix fuel pump at ws6 store what do you guys think of it and im gooing with hotwire kit upgraded ground not shure about booster. how many versions arew there of the racetronix in tank fuel pump for trans ams.
http://www.ws6project.com/user_stor/...x-fuel-system/
thanks for help not looking forward to taking tank down and dont wana cut my floor.
Old 07-15-2012, 06:27 PM
spiro27's Avatar
I am running stock fuel rail and regulator. Will I need a new fuel pressure regulator with a new fuel pump. Will I need to cut or crimp any wires for the fuel pump install.
Old 07-17-2012, 07:09 PM
TransamGCS's Avatar
racetronix with hotwire kit is the way to go dont have to cut or crimp wires very easy instructions just make sure you have the two sock filters my racetronix kit came with them but some dont i got mine from ws6 store might as well replace the regulator while you have every thing apart
Old 07-18-2012, 07:42 AM
devic's Avatar
dude do not get the racetronix hot wire kit its a rp off, get the casper same thing for 35
the racetronix kit is 75
Old 07-18-2012, 10:27 AM
Ollie8974's Avatar
That is the correct pump for the 01. The jet nipple is clearly shown in the photo. Some vendors will say they offer the correct pump, but they are not.
With out the jet pump the fuel pump will not operate correctly.
Old 07-18-2012, 10:55 AM
Black_Thunder_00WS6's Avatar
I am running the same Racetronix pump with the hotwire kit, also purchased from WS6store. Works great! Pretty easy install too, as long as you don't have a full tank of gas... Good Luck!
Old 07-18-2012, 11:23 AM
TransAmcoupe98's Avatar
Racetronix is good ****. Ive had 3 racetronix kits, and easy to install compared to others.
Old 07-18-2012, 06:15 PM
spiro27's Avatar
Do I need to change the regulator on the fuel rail. Or am I okay to just put fuel pump kit in and it be okay.
Old 07-20-2012, 04:16 PM
spiro27's Avatar
does anyone know if i need to change the in take regulator? or have a write up on how to change it. it it nessisary for my setup how much i t costs. will my stock fuel rails be okay for all of this with new pump. thanks for help.
Old 07-21-2012, 09:03 AM
Ollie8974's Avatar
The 01 regulator is in the fuel pump module in the tank not on the fuel rail. No you do not need to change it.
Attached Thumbnails racetronix fuel pump-img_1009cropped.jpg   racetronix fuel pump-img_1012cropped.jpg
Old 07-22-2012, 01:07 AM
spiro27's Avatar
thanks for help im gona put a fuel pressure sensor on it while its out. should i put regulator in it just for cheep insureance. do the in tank regulators have any problems usually.
Old 07-22-2012, 01:16 AM
ls1wallen's Avatar
you can get a new regulator from rockauto pretty cheap if you want to play it save while your in there
Old 07-22-2012, 01:27 AM
spiro27's Avatar
the stock one would be fine for my setup. does anyone have the part nuber for it. think im gona do fuel level sensor too and fuel pressure sensor. ijust wana do it all one time. taking diff out goin through all the work to take tank out i dont wana ever go in there again.
Old 08-14-2012, 11:08 PM
spiro27's Avatar
with the racetronixs pump what should the fuel pressure be at key on and running.
Old 08-14-2012, 11:23 PM
spiro27's Avatar
im getting 50 psi key on is that good.
Old 08-15-2012, 05:46 AM
spiro27's Avatar
i have 49 psi key on engine off. 61ps1 engine running. when i rev it up its stays the same and when i release throttle.
Quick Reply: racetronix fuel pump
