Fuel pressure on the return side? - LS1TECH
Thread Tools Search this Thread
Old 07-16-2012, 11:39 PM   #1
Default Fuel pressure on the return side?
Hi guys please forgive my stupid question.
I am retrofitting a 2001 5.3 truck motor into a classic impala,just wondering what kind of pressure the return line has? i am running both feed and return lines and i know the pressure on the feed side just unsure of what kind of pressure is in the return side? Any help would be greatly appreciated.
Micah Johnstone is offline   Reply With Quote
Old 07-17-2012, 07:45 AM   #2
What type of fuel pump and regulator are you using?
If it is an after market external with the regulator on the fuel rail the return line is not pressurized.
If you are using a 4th gen in tank fuel pump module the fuel pressure regulator is in the module pressurizing the return line
Ollie8974 is offline   Reply With Quote
Old 07-17-2012, 08:47 AM   #3
Thanks for the info Ollie, i am using factory 2001 truck intake with regulator on the rail,so that answers my question,Thanks
Tags
53, fuel, pressure, rails, return, side, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
