Had an injector o-ring blow out while i was driving..(update 8-3) - LS1TECH
Thread Tools Search this Thread
Old 07-25-2012, 05:47 PM   #1
Ryans99ls1's Avatar
Default Had an injector o-ring blow out while i was driving..(update 8-3)
luckily the car did not catch on fire but the it was SOAKING the motor in fuel. Im running siemens 80lb injectors with fast fuel rails. is there any way to prevent this from happening again? im already replacing all the o-rings but im worried its gonna randomly happen again. the car has been fine under boost, it happened under normal driving
Ryans99ls1 is offline   Reply With Quote
Old 07-25-2012, 06:24 PM   #2
LS1Tech Sponsor
FICINJECTORS's Avatar
Quote:
are you sure you have the right bottom o ring? I ask because there is a 15mm o ring that should be used on the manifold side, the siemens comes stock with a 14mm. are you sure the injector is not too low in the rail as o rings don't just blow out if they are relatively new
FICINJECTORS is offline   Reply With Quote
Old 07-25-2012, 06:34 PM   #3
Ryans99ls1's Avatar
Quote:
im almost positive the injector is fully seated. i put them in the rail first then pressed them into the manifold, none were uneven. when i first put them on, one came leaky from the factory. replaced it with one from my stockers and it sealed right up. this is not the same injector though
i wouldnt be suprised if the injectors dont have the 15mm oring on the bottom. from what i remember all the orings looked the same (blue). where can i get the proper 15mm ones?
Old 07-25-2012, 07:10 PM   #4
RezinTexas's Avatar
I'm planning to keep one of these in the truck. It wont damage the engine from corrosive chemicals or thermal shock.
Amazon Amazon
RezinTexas is offline   Reply With Quote
Old 07-25-2012, 07:34 PM   #5
LS1Tech Sponsor
Sorry my bad, I thought you had a 102. Ls6 manifold uses 14 top and bottom. I guess you need just o rings
Old 07-26-2012, 08:30 AM   #6
Ryans99ls1's Avatar
Quote:
http://www.amazon.com/H3R-Performanc...e+extinguisher
hahaha yeah im planning on picking one up after this little scare. im only laughing cus i asked how to keep this from happening again you posted a fire extinguisher.
i hope they do the trick. thanks for the help.
im still open to hear what anyone else has to say!
Old 07-26-2012, 08:42 AM   #7
Zmg00camaross's Avatar
Sometimes **** happens. You may have slightly pinch it when installing and took a while for it to blow it out. Had it happen to me took 2 weeks before it happend. Just lube the o ring install the injector and probly not happen again.
Zmg00camaross is offline   Reply With Quote
Old 08-03-2012, 05:32 PM   #8
Ryans99ls1's Avatar
alright so it turns out i did infact have a pinched o-ring. replaced it and it was much better. BUT its still leaking somewhat.
i replaced all of the o-rings on that side and the front 2 injectors feel pretty sturdy once they are in. The rear 2 basically fall out on their own if they are shaken a little bit. i switched the injectors around so i know its not that.
anyone else know a better way to make them seal or how to maybe get more force on the rail?
Old 08-03-2012, 05:51 PM   #9
Old Geezer's Avatar
Check the rail bore sizes.
Look to be sure the rail hold downs aren't flexing.
Look at the bore finish in the rails. When they are drilled, there is a chance the bit could leave a scratch/groove.[Dull drill] I had another brand that had scratches in a couple of the bores. Had to buff them with a cross buff from Powerhouse tools.
Old Geezer is offline   Reply With Quote
Old 08-03-2012, 05:59 PM   #10
Ryans99ls1's Avatar
I checked the bore on them, there werent any scratches or anything. Ill have to get the dial calipers out and check the roundness though.
Ill look into the mounts flexing too. thanks!
Old 07-12-2013, 12:37 AM   #11
Did you solve this? Same injector and rails on a 102. It happened to me today. How do I tell if I have the right o rings?
charlesready is offline   Reply With Quote
Old 07-12-2013, 07:44 AM   #12
1bad03snake's Avatar
How much fuel pressure are you running?
1bad03snake is offline   Reply With Quote
Old 07-13-2013, 12:49 AM   #13
Quote:
58 psi base and boost ref.
Old 07-14-2013, 08:45 PM   #14
Ryans99ls1's Avatar
Quote:
What i actually did is make new fuel rail mounts that reallly pull down the rear portion of the the fuel rail. If you the look at where the mounts bolt to the manifold, the front mount is much closer to the end of the fuel rail, the rear is more towards the center. The rear one being closer to the center obviously doesnt put enough pressure on top of the back injector which makes it very easy to blow one out if the oring is not perfect. I check it all the time now and its been fine since.
Related Topics
Thread Thread Starter Forum Replies Last Post
42lb injector recomendations gnnova Fueling & Injection 2 06-08-2016 07:22 PM
Injector O-rings for MSD intake gomer Generation III External Engine 0 05-14-2016 09:57 AM
Fuel injectors keep popping out of the fuel rail Slash8915 Texas Members 24 10-19-2014 12:17 AM
Top injector o-ring came out of fast fuel rail Buford17 Generation III External Engine 5 10-06-2014 11:19 PM
Fuel Injector spacer not fitting blackws620 Generation III External Engine 3 01-26-2014 01:55 PM
Tags
102, 15mm, blowing, blown, blowout, fast, front, fuel, injector, leaking, ls1, oring, orings, prevent, rings, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
