Connecting to stock fuel rail
Old 08-26-2012, 09:25 AM
steve_d's Avatar
Default Connecting to stock fuel rail
Hi
Treat me gently I'm new here.
I have a stock LS1 going into a UK kitcar. The fuel system will be -6 braided hoses with aeromotive style fittings.
Can someone point me at suitable adaptors to connect -6 to the OEM push-on connection to the fuel rail?
I plan to use the same fittings to connect the OEM filter/regulator unless I'm advised against using this item in favour of aftermarket filters and reg.
Thanks in advance for your help.
Steve
Old 08-26-2012, 12:30 PM
JaYZeig's Avatar
hope this helps..
http://performanceparts.com/part/Russell/640863
Old 08-26-2012, 05:29 PM
steve_d's Avatar
Spot on.
Thanks for that.
A Google with the part number also took me to Summitt where I also found the male version.
Thanks again
Steve
Old 08-26-2012, 07:31 PM
JaYZeig's Avatar
good deal
Old 08-27-2012, 06:09 AM
Ollie8974's Avatar
Make shure you get the new version.
Part Number 644120 and 644110
http://performanceparts.com/part/Russell/644120
http://performanceparts.com/part/Russell/644110
Attached Thumbnails Connecting to stock fuel rail-assembly-step-1-russell-644120.jpg   Connecting to stock fuel rail-assembly-step-2-russell-644120.jpg   Connecting to stock fuel rail-assembly-step-3-russell-644120.jpg
Old 08-27-2012, 02:48 PM
steve_d's Avatar
Is the clip on version not so reliable?
Steve
Old 08-28-2012, 05:58 AM
Ollie8974's Avatar
Yes, they have been known to slip off under running conditions spraying fuel all over a hot
Engine. Have not heard of any fires .
Old 08-31-2012, 03:04 PM
steve_d's Avatar
Thanks.
Will go with the new version.
Have witnessed (standing right beside it) a fuel rail popping off the injectors before so don't wish to go there again.
Steve
Old 09-03-2012, 10:49 PM
flash911's Avatar
I have....
Quick Reply: Connecting to stock fuel rail
