Fuel Pressure regulator
Old 08-26-2012, 06:10 PM
pulse's Avatar
Default Fuel Pressure regulator
Just ordered my new fuel pump and was wanting to install a new FPR. Its for my 99 t/a and was wondering if anyone had the part number so i can get it orderd. Any helkp would be great. Thanks
Old 08-26-2012, 07:38 PM
pulse's Avatar
Anyone......
Old 08-26-2012, 07:54 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I'm not sure you can buy them from GM... I do not have the GM part number.
I have them in stock if interested.
Feel free to call if you want to discuss.
Old 08-26-2012, 09:13 PM
pulse's Avatar
Darn i just perchased one from rockauto. If its not the correct one ill get it form you if the price is reasonable
Old 08-26-2012, 09:21 PM
pulse's Avatar
this is what u purchased
http://www.rockauto.com/dbphp/x,cata...i_FP10021.html
Old 08-30-2012, 12:20 AM
Stequin's Avatar
Well if you want to know about signals of bad fuel pressure regulator it is lack of fuel pressure, maximum fuel pressure, rich engine running condition and black smoke. To make sure these does not affect your car you should take precautions before hand.
Old 09-01-2012, 04:16 PM
Mr Ed's Avatar
Delphi FP10021 is correct.
I just replaced mine in a 1999 Z28. The best price I found was $55.25 w/ free shipping from amazon.com. So, if you paid $47.79 you did good.
After I had already purchased mine, Lonnies Performance posted that he had them for $39. I would have gone with a board sponsor if I had known.
Old 09-04-2012, 07:46 PM
HRHohio's Avatar
Any recommendation on a boosted application?
Setup: 2002 Z28 Convertible w/76mm Rearmount Turbo
Aeromotive 340 Fuel Pump
Racetronix Hotwire Kit
60lb injectors
Otherwise stock fuel system
Running out of fuel at 9psi. AFR climbs to 13
Thanks!
Old 09-05-2012, 06:59 AM
Ollie8974's Avatar
60lb injectors
Thanks!
Read this post #3 vacuum referenced with a pressure gauge.
https://ls1tech.com/forums/fueling-i...selection.html
Old 09-05-2012, 09:40 AM
HRHohio's Avatar
Sweet. Thanks... Got a specific part number? A quick web search for "aeromotive regulator" turned up a bunch with different numbers... 13109, 13121, 13129, 13301, etc. Was hoping to have a sponsor spec one out for me and purchase through them.
Thanks in advance.
Old 09-06-2012, 08:06 AM
Ollie8974's Avatar
Regulator with a gauge that is vacuum referenced and reads to 100 psi.
The 50 to 60 psi will bin the center of the gauge.
Quick Reply: Fuel Pressure regulator
