Fuel system setup
Old 09-08-2012, 09:45 AM
fastmach01's Avatar
Default Fuel system setup
Im new to the GM world...owned nothing but mustangs the past 6 years. Sold both mustangs and bought a 2002 Camaro SS. To make a long story short im putting a built motor...standard CI 346 just full forged internals, cnc ported 5.3 heads, trex cam and going to keep the stock ls6 intake for now. I plan on running a 200 shot of nitrous threw this thing and just want on the fuel system setup that would be best for me. I already have a set of cobra 39 lb injectors to use. Any input would be great. Thanks
Old 09-09-2012, 03:26 PM
ZL1Killa's Avatar
racetronix 255 bolt in kit w/wiring harness suggested. those 39# should be fine. and if they are cobra 39# injectors rated at 43.5psi, your camaro runs at 58psi so they are actually 45# injectors.
Old 09-09-2012, 08:19 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You better look into Cobra injectors in more detail.
Fuel Injector Connection posted a video of the Cobra Spray pattern.
It is not good with the LS1 ports as it sprays onto the port walls.
Here is a link.
http://www.youtube.com/watch?feature...&v=BdQeA77skuk
I have the Racetronix pumps in stock if interested.
They are good into the 550-600rwhp range on N2O.
If you need more, I can also provide a dual pump kit.
Quick Reply: Fuel system setup
