edelbrock pro flow xt injector question
Old 09-26-2012, 07:05 AM
Hhoover's Avatar
Default edelbrock pro flow xt injector question
I have a 2004 5.3 that I am putting an edelbrock pro flow xt intake on. my injectors are stock for the 5.3 the part # is 25317628. will this injector work with this intake or do i need to go with another style? The part # for the intake is 7139. It seems like the injector is too long and the fuel rail doesnt want to line up with the mounting holes. Thanks
Old 09-26-2012, 07:18 AM
Old Geezer's Avatar
Look at the Edel pt # 3629 rail kit...Likely why the stock rails don't fit.
Old 09-26-2012, 08:34 AM
Hhoover's Avatar
Sorry I Didnt tell ya. I am using the Edelbrock fuel rail for that intake. The injectors fit the rail. It seems like they are bottoming out on the intake side. My injector has a plastic ring on the bottom of it. I hope I can use my stock injectors because that's what my harness and computer is set up for. I'm new to the LS stuff and not sure if the LS injectors are interchangeable. Thanks for the help
Old 09-26-2012, 09:04 AM
nick.celis's Avatar
you can also get EV6 Injectors, and buy the EV1 to EV6 pigtail adapters that FAST makes fairly cheap if you decided to get different Injectors
Old 09-26-2012, 09:18 AM
Hhoover's Avatar
Thanks!! Where do I get the ev6 injectors? Are they a stick injector of aftermarket?
Quick Reply: edelbrock pro flow xt injector question
