1500fwhp with magnafuel 4303?
Considering using this set-up:
sumped tank
-10 off sump/prefiler to pump
magnafuel 4303 with -10 supply
-10 feed
-8 return
I have seen it mentioned several times that a -12 supply to the pump is ideal. This is not really feasible with my set-up. Will the way I run it support 1500fwhp with twin turbos? Would I be better off running one of their MP-4101s?
Thanks.
sumped tank
-10 feed
-8 return
Thanks.
Do Magnafuel or any similar companies offer any flow data for such pumps ?
Quoting 2000hp is pretty meaningless when they claim that is n/a only
And a range of 20-120psi is also meaningless without flow data vs pressure.
