Fuel system routing? Which way? Pictures
Old 10-07-2012, 01:35 PM
tording99Z28's Avatar
Default Fuel system routing? Which way? Pictures
What is the preferred way to run a fuel setup on a high horsepower (1000 hp) turbo car. I am pretty sure I know but I have seen some pictures of guys builds that look like they did it different and I want to know what the general consensus is.
First Method: I think this is not the preferred way but what kind of power is this setup good to?
Second Method: I believe this is the preferred method but what kind of power do you have to be making for this to be necessary?
If you set it up like in method 2 do you have to have a regulator that is termed a "bypass regulator"?
Old 10-08-2012, 05:19 AM
PewterZCar's Avatar
huh?
I'm confused.
I have mine ran from the pump into a Y fitting, into the back of both rails, then out of the front of both rails into the regulator. Then ran a return from the regulator all the way back to the top of the tank.
Old 10-08-2012, 03:42 PM
T76s10's Avatar
heres mine
you'll probably need a -8an return line though
Old 10-08-2012, 03:50 PM
I need a gauge for that
Atomic's Avatar
Not sure if you meant to post pictures with your post or not, but...
I have the pumps feeding a single -8 to the back of the driver rail, -8 crossover from the front of the driver side rail to the front of the pass rail, -8 line to the regulator, and -6 back to the tank
Old 10-09-2012, 07:13 PM
Turbo2L's Avatar
Originally Posted by T76s10
heres mine
Any reason you put the filter after the pump? Most people like to filter their fuel before it gets to a higher dollar part.
Old 10-09-2012, 07:17 PM
burbalanche's Avatar
i have a filter before and after pump.feed goes to a y block into each rail then to regulator and return back to tank.
Old 10-10-2012, 05:28 PM
T76s10's Avatar
i was going to put one before and after but i didnt want to pay another $70 for another filter lol. i should have it before your right though. once i upgrade the fuel system i will do it before though.
Old 10-10-2012, 05:30 PM
T76s10's Avatar
i guess my main concern was not getting any **** in my injectors. $340 injectors > $180 pump. two filters would have been the best way to go though
Quick Reply: Fuel system routing? Which way? Pictures
