Help... Stock pump???
is the stock fuel pump branded Racetronix? guy i bought car from said it had stock fuel pump. Car's up in the air getting ready to swap pumps and guy called me and said pump i was going to swap is bad (going to follow up with member from here for selling me bad Racetronix pump) but also said pump in the car now is also a Racetronix but just a lil different from the one i bought..? he's waiting for me to make a decision and i dunno what to do..help
Is there a Racetronix pump below a 255lph? or, are all Racetronix pumps 255 and above? Reason i ask its according to mechanic, pump already in car it's a Racetronix but a little different than the one i bought which it actually had 255lph inprinted in it and with red casing with the words RACETRONIX... Before i tell him to put everything back in the tank and go through the trouble of reinstalling everything back in the car, i want to make sure i don't have a pump lesser than a 255lph .... Anyone?? I already asked him to ck pump to see if it had any LPH's rating on it and he said he didn't see nothing
what should i do? i want to spray a 125 dry. i was previously spraying a 75 and everything seemed ok, i'm adding a Racetronix hot wire upgrade. it sucks not knowing what lph my current pump flows and getting shafted here by a member selling a bad fuel pump...
Just went to the shop and had the 2 pumps side by side. The p.o.s one I got from the individual on this forum says, Holley HP by Walbro gss346 14903-2.
The one that was in the car just says WALBRO 12704-2 0884 by connector
PAT 4500270-5421306
same as the other pump.
the only difference I noticed was, the incar pump on one end had like a tower head a nipple and a 1/4 orifice, the pump I bought on that end of it just has about a 1" opening with a mesh filter, that's it, pump sizes are the same... help?
While the car's on the shop lift waiting for an answer, would be nice if one of you fuel gurus would let me know at least if any of those numbers from previous post mean anything? I would be grateful to an answer, thanks in advance..
