aeromotive 340 dead after 9mth e85
Old 11-24-2012, 11:42 PM
dogsballs's Avatar
Default aeromotive 340 dead after 9mth e85
my relatively new (jan/feb) aeromotive 340 intank fuel pump died yday, just cruising home (convenietly in the middle of crossing a busy 6 lane road, also nice $100 tow truck albeit 3 km from home). i run e85 and probably done 2-3k kms in that time. the sock filter looked relatively clean and i changed the fuel filter ages ago when i switched. checked the connections in case my handy work had failed but all good. tried giving it a tap against the bench but still no good.
i ran a new filter and also a fine filter sock, with the mesh behind it. not convinced its e85, or sitting still as its done 2k since back from holidays. could be dud internal wiring.
just had a play with some power feed straight to the pump. i don't get anything if i go the main plug terminals. i get a low speed noise if i go the small dimple feeds, NO fluid movement, even if i change polarity. i get a high speed noise if i go negative on the dimple and positive on the main pin, NO fluid movement. so somethings up.
Old 11-27-2012, 09:04 PM
Monte4ever's Avatar
I asked Lonies Performance about those pumps over a year ago and he stated that some were having problems with those pumps.
Old 11-28-2012, 02:29 AM
dogsballs's Avatar
well i'm having trouble getting contact with aeromotive, which is disappointing.
Old 11-30-2012, 11:04 AM
Mr. Fuel Pump's Avatar
These 340 pumps are not properly designed, nor utilize the proper materials, for use in E85 fuel.
Old 12-07-2012, 05:56 PM
oange ss's Avatar
elaborate please.
Old 12-09-2012, 01:40 PM
I've covered this topic quite a bit on this forum over the last couple years. Basically the electrical connections aren't sealed and the pump includes copper, brass and other metals that are susceptible to corrosion when used in high alcohol fuels that attract water. It simply does not include the typical upgrades evident on OEM flex fuel pumps used in current/past OEM flex fuel/E85 vehicles. You can use it at your own risk, it may last 1-2 years for some, a couple months for others, it depends on a lot of variables; temps, humidity, pump submerged or not, % of ethanol content, how often you drive the car.
Old 12-09-2012, 02:41 PM
oange ss's Avatar
10-4, thanx
Old 12-10-2012, 12:25 AM
Aleken's Avatar
Good luck!
Quick Reply: aeromotive 340 dead after 9mth e85
