FAST injector spacers on a LS2 manifold ... stock O-rings?
Old 12-29-2012, 09:49 AM
DuronClocker's Avatar
Default FAST injector spacers on a LS2 manifold ... stock O-rings?
When using the FAST injector spacers to use an LS3-style injector in an LS2 manifold, what O-rings are required? The injector will use the stock LS2 upper/lowers I imagine, but I need to figure out what O-ring to put on the spacers.
Do I need FAST O-rings or stock LS2 lower O-rings? FAST was not overly helpful when I was chatting with them the other day when I told them I wasn't using them on their manifold.
Specifically, I'm swapping an LS2 intake onto my LS4, retaining the stock injectors (LS3/LS7-style) and fuel rail (needs spaced up 1/2-5/8" to clear the intake)
Old 12-31-2012, 02:57 PM
Nobody has used the FAST injector spacers to use LS3/LS7 injectors on an LS2 intake?
Old 12-31-2012, 11:58 PM
marc.madmax's Avatar
Yes I have stock injector o-ring worked fine with the Fast spacer accessory. Used an Aeromotive fuel rail but needed to fab brackets for it to work. FAST should have their kit complete. here is a pic or two. The fuel lines have not been installed but the setup is tied down.
Attached Thumbnails FAST injector spacers on a LS2 manifold ... stock O-rings?-motor-1.jpg   FAST injector spacers on a LS2 manifold ... stock O-rings?-motor-4.jpg
Old 01-01-2013, 09:48 AM
Awesome thank you very much for the response.
Quick Reply: FAST injector spacers on a LS2 manifold ... stock O-rings?
