walbro 255 vs aeromotive 340 stealth
Dont forget to do the " Trap Door " Mod for easy Fuel pump access.
This Modification will give you easy access for future fuel pump access or maintenance.
Heres a couple of links...
http://ltxtech.com/forums/showthread...-Door-Mod-PICS!
http://www.mifbody.com/vbulletin/sho...res-and-How-To
bump, ive been looking but cant find anyone that says it fits. anyone put an aeromotive 340 in the stock bucket, is it a perfect fit like the racetronix 255? im guessing part 11169 is the one needed? my racetronix is maxed out now with the hotwire kit.
I know I can call them but I'm looking for real world experience from anyone on here. Trying to see what kind of problems people ran into installing them and how well are the pumps working.
Okay guys I finished the pump swap today I went with the 11140 and to say loving the pump everthing went on fine and easy didn't run into any problem and the pump is very quit psi before pump 40 now psi back to 59
How well will the aeromotive 340 work with the racetronix hot wire kit? also do you sell the 340, can you pm me a price?
Lonnie... I have the Racetronix Harness kit with the Walbro 255 lph Fuel pump installed in my 98 Camaro.
Would the Aeromotive 340 pump plug into my Racetronix Harness & mount in place of my Walbro 255 with no modification ??
LS1TECH Sponsor
No, the wiring bulkhead in your 98 sender is not rated for the current that pump draws. This part can be upgraded on the 99 up sender, but it is not on the 98.
The hot wire kit you have does nothing to change this.
Feel free to call if you want to discuss in more detail.
