Running a second fuel pump off eboost 2
Old 01-04-2013, 12:49 PM
703 CAMAROSS's Avatar
Default Running a second fuel pump off eboost 2
The Eboost 2 has an output you can set to a specific boost. So I could use this output to run my second fuel pump and eliminate the need for a hobbs switch. Do you all think this will work as I plan? And do you guys think I would still need to run a relay?
Old 01-16-2013, 09:54 AM
MIGHTYMOUSE's Avatar
yes will work fine and yes you absolutely need a relay
Old 01-25-2013, 06:34 AM
Thanks mighty mouse, I figured I would still need a relay, wasant sure how many amps those walbros draw.
Quick Reply: Running a second fuel pump off eboost 2
