Fuel pump/ Injectors?
I'm putting together a LS6 that will hopefully get close to 500whp what fuel pump and injectors will i need? Will a walbro 255lph and 36lbs do it or will i need more?
Also what is the difference in the 98' F body fuel system compared to the 99-02's?
This is why i'm asking i did search and got lots of different results i originally thought 60's and a single walbro but most reported 30-36's did the job easy being the system is 58lbs.
Well i emailed Racetronix today and they said their f98 255lph pump kit and siemens 60lb injectors will handle the job. Injectors seemed still a bit big considereing they will probably have a higher lb rating at 58psi but i'm no expert here!
