Fuel system help needed!!!!!
i need to figure out a fuel system for around 6 or 700 bucks. I need an external pump, filter, regulator and all the AN fittings I would prefer to use Stainless flex line. Can someone help me get this sorted out?
look at the write ups from Mightymouse and others in the sticky section of this forum section.
Depending on what power you need it for, you might be able to do it. If you are on the high end power 750+; I doubt you will be able to do it for that price.
I'm doing a cam,intake exhaust 5.3 in my truck right now so no more than around 400hp im guessing but I'd like do have an aluminum fuel cell behind the axle with an external pump. the internal pumps ones are just a little confusing for me.
