160lb injectors Help
Well I am having issues and I am sure its because I am doing something wrong. I had purchased a new set of smartfire injectors ( 160lb ). I started the car for the first time last night with the new injectors. It started with a litle help from the gas peddle. I ran it up for a little while of course it didnt want to idle. I tried to let it idle on its own and it died. I tried to restart the car and it pretty much hyudrolocked? I looked under the car and that was fuel coming out of the down pipe. I stopped everything I was going and just let the car sit. About an hour or so later I was in the houde thinking about what I need to do. So I went out and tested every injector to see if I had one stuck open. They all clicked when sending ground to them so I would think that is not it? It was showing around the 9.4 range on my wideband at idle. I am running e85 and the stoich value in HPT is set at 9.84615. My Wideband is still showing gas value just so you know. I am running smartfire injectors 160lb with a versafueler driver box and a boost ref reg. I installed the correct IFR in HPT 152lb is what the spec sheet said. I also have dead timne data ( dont know what I do with it? ) Do I need to adjust the min pulse width, short pluse limit ect? I dont know where to start. So here I am asking for any help I can get this where it needs to be. Thanks
Set the HPT stoich back to 14.625ish, and tune for that on the gas WB, follow basic gas scaling for your cruise/idle/PE/BE assuming it is a basic intercooled 650-800hp combo.
May want to pull plugs, crank the motor over to make sure the cylinders are dry, change plugs and start again.
Slowhawk
I figured I would have to change that stuff. How do you determine the short pulse limit, min pulse, adder ect. Right now my short pulse limit is at 3.997 I would think this needs to be reduced a LOT? But I am not sure thats why I am asking. Thanks for the help.
14.62857 and yes that is one reason why you were running so rich, correct injector data is another reason, VE tuning, and OL EQ ratio are a few others. Your combo is going to like different AFRs at different loads, and temps, so your commanded AFR is going to vary depending on those and what you need to target.
This is what he sent me via email. What do I do with this info. My injectors are the 1600cc ones.
CC/min LB/Hr Ohm 10v 11v 12v 13v 14v 15v
43.5 PSI 440 42 13 1.27 1.08 0.91 0.74 0.63 0.53
43.5 PSI 550 52 13 1.07 0.88 0.78 0.67 0.55 0.46
43.5 PSI 650 62 12 1.08 0.86 0.69 0.54 0.41 0.31
43.5 PSI 850 80 12 1.36 1.12 0.92 0.76 0.63 0.50
43.5 PSI 1000 96 3 1.17 0.95 0.80 0.67 0.56 0.46
43.5 PSI 1200 114 3 2.55 2.28 2.00 1.79 1.62 1.46
43.5 PSI 1600 152 3 1.80 1.46 1.23 1.05 0.92 0.81
You bought trouble, those injectors are Chinese junk, get them on a flow bench they will be all over the place. Read the reviews they are a big problem. They are 8.00 each on amazon .. Chinese should stick to fortune cookies not injectors that will blow up our engines.
Ok I am finding more and more reviews on these. I am not dealing with it. What injectors should I buy? I want this project to be done. These injectors have caused me lots of trouble already and I am not dealing with it down the road. I already have the versafueler but I can take that out if I need to. Who should I go with people? Help me out here!
Called and talked to Jon at FIC and he hooked me up with the right injectors for my setup. Cant wait to get them! Jon is a great guy to deal with! I will back on to update once I get the injectors. Should have been smart enough to get ahold of FIC right away.
