fuel pump wont turn on new pump relay etc
hey guys I have a 2002 Camaro. swapped in a 98 drivetrain with the 2002 computer and harness. I got the correct temp sender. car ran and drove after the swap. all of a sudden doesn't want to start so I replaced the pump and relay under the hood. Car still wont start. it cranks but no fuel. I have spark. theres no fuel in the fuel rail. with the new fuel pump I had a new connector and had to splice the wires in and I followed the instructions and its all connected. the 3 wire plug has power to it. So im very confused on why the pump still isn't turning on. any ideas?
You should try to put power directly to the fuel pump assembly. The three wire plug is not where the pump gets power. Power is on the 4 prong plug in the center of the assembly.
