anyone had this code thrown? p0102
Old 04-30-2013, 03:27 PM
wnarunm's Avatar
Default anyone had this code thrown? p0102
have 98 ls1 in 69 camaro throwing code p0102 says low input mass airflow. want to see if anyone has had this issue , i figure its bad mass air possibly?
Old 04-30-2013, 04:09 PM
joecar's Avatar
P0102
Old 04-30-2013, 04:14 PM
camaroz98's Avatar
had it last week in my 98 z28 with ls1, shot the wires to the MAF and got incorrect readings. thought i had a broke wire but if you are running the ls1 wiring and fuse box, there is a 20amp fuse labeled Engine Sensors and its actullay your MAF fuse mine was blown. threw in new fuse and code went away. also if you have the ls1 wiring i know what wires you need to check to find out if its MAF, wiring or fuse
Old 05-01-2013, 11:04 AM
joecar's Avatar
Did you find out what caused the fuse to blow...?
Quick Reply: anyone had this code thrown? p0102
