delphi racetronix 42lb injectors data
contact racetronix, most of the time with such injector(s) of this sort, there is no data. as they are disc they will respond quicker, so you can lower your offset table by some percentage not certain what people do. and just tune your IFR. if you need IFR data I can get you that. are you running them at 43.5psi or 58psi? manifold referenced fuel pressure regulator or not?
you do realize you have posted this in the PCM & Diagnostics & the Fuel & Injector page.
