Can someone show me where the venturi tube connects?
Hey guys, did the Walbro pump years ago and I'm installing the Racetronix now. Obviously the Walbro didn't use the venturi tube so now I don't remember where it hooks up to. I'm also going to have to hope I can find some hose to fit that size at the store as I have no idea what happened to mine. Thanks!
I have cut the bottom half from previously running the walbro. Would I have cut out what it connects to? Do I have to run it on the Racetronix or can I leave the tube off like the Walbro?
As I bought a brand new fuel module and a new pump from racetronix I still have my stock unmolested fuel module that I pulled this weekend. I will take some pics of where the venturi goes when I take the two halves apart tomorrow to install a new GM pump before putting it up on eBay for someone that needs a 10 year old fuel module (pressure regulator, sender, basically everything except the pump) with a brand new stock GM pump. I'll post the pics on this thread. I'd take pics of the new setup with the racetronix pump but its in the car now.
hope those pics help, yes I am selling the entire stock GM fuel module (pressure regulator, level sender, float, socks, plastic buckets, EVERYTHING) in case someone needs one out of a 77K miles 2002 Trans Am WS6, the pump went out so I upgraded to all new stuff but the fuel module minus the pump was working perfectly fine, I also have a brand new GM fuel pump
