ls6 injectors big enough?
Before I solder on the pigtails for the ls6 injectors into my wiring harness, I guess I should ask, are stock ls6 injectors big enough for the motor listed below?
'02 lq4
243 heads, stock other than springs and having .008" surfaced off
ls9 head gasket
futral f6 112 cam
1 7/8 long tube headers
ported ls1 thottle body
stock ls6 intake
if not, what would be a cheapish alternative, and will I need different pigtails for the injectors, AND will it work with the stock fuel rail?
thanks in advance for any help
'02 lq4
ls9 head gasket
futral f6 112 cam
stock ls6 intake
I have similar mods on mine and i am running stock injectors at 90%. Running the injectors higher than 70-80% usualy just makes them go back faster.. I would think you would be ok until they go bad.
