ls1 truck fuel problem
I have a 1999 round body style silverado with a ls1 with MS3 cam shaft and 2.5 heads. The truck had a 4.8 in it and I used all the truck accessories even the intake and injectors . At first when you would go to WOT all it would do was skip , pop and break up . I thought maybe It was just it needed to be tuned . I had it tuned and it now only breaks up at high rpms . Could it be that the 4.8 injectors are not supplying enough fuel for the ls1. IF so what injectors should I use ? ls1 injectorswill not plug into the truck harness.
