FAST 102 injectors.
FAST 102 injectors.
Anyone with the FAST 102 have problems with their injectors fitting into the injector hole? What kind of injectors do you use? my 42lb injectors are too fat and wont fit into the intake.
I also found out the hard way that the 42 lbs don't fit. I ended up going with the following:
Seimen Deka tall style injectors (same dimensions as stock LS1)
Billet nasty performance rails with brackets for "tall" injectors
Lingenfelter o-rings for the bottoms to seal in the fast 102.
The 102 lower bosses are made for LS2 style short injectors which are bigger in diameter, hence the special orings. Funny how a $700 intake ends up costing you another $600 in injectors and rails....
Oh BTW Boomer Sooner!
