goes lean only on right (sharp) turns
i just noticed this after i got the car up and running swapping the 98 pcm to a 02. for example, when i turn onto a street and gas it some the motor will stutter and my wb goes "----" meaning lean ofr a couple seconds then it'll go back to normal/stoichmetry. doesnt do it on left turns. any idea(s) on what to look for? im running 36# L67/GTP injectors with unknown miles but at full throttle it doesnt go lean at all.
i think you're right. when i swapped to the 02 pcm i had it sent to shortuning to get the fuel segments updated and james (who went far and beyond and helped me on the right track-highly recommend him!) said that i would also need to adjust the fuel tables on my end in HP Tuners. after some adjustments i found that the fuel gauge needle was just above empty (i poured 4gallons prior) but drove 50miles on 3.73 gears so i imagine it was low again. i filled up yesterday to 6gallons and so far so good.
