twin pump issues..
Old 08-16-2013, 10:34 PM
02_ramair_ta's Avatar
Default twin pump issues..
I installed a 2nd pump in my tank.. 01 formula.. I followed the "DIY on the cheap" write up, but I think I might be having issues with the pumps uncovering at about 1/2 tank... the car idles good for a large cam, but once its lower than 1/2 tank it will die out, and hates running.. basic "out of fuel" feeling.. So I am pulling the pumps and going to re-check and and tighten stuff down..
my primary questions are..
the small 1/4 nipples on the pumps are for what?
I used teflon fuel safe tape on my fittings(yellow)
I used 5/16 fuel injection hose, and issues there?
I had to mod the bucket to make this work, do I need to just replace the bucket and start over? By mod, I cut it up to make the 2nd pump fit.
thanks in advance, Ill post pictures tomorrow..
Old 09-08-2013, 12:03 PM
still having issues.. I didnt get around to pulling the pumps, I will be doing that today...
any advice on what I need to look for, or how to test or check to ensure im not bleeding pressure with a loose line or something?
Old 10-15-2013, 01:23 PM
sparkwirez06's Avatar
this is the only true submergible hose I could find. http://www.oreillyauto.com/site/c/de...0887&ppt=C0222
Old 10-15-2013, 06:31 PM
Ollie8974's Avatar
These are the OEM in tank tubes.
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
Old 10-16-2013, 11:27 AM
01boydws6's Avatar
if you didnt put anything on the small venturi nipple on the top of the pump you will be spraying fuel at the top of the tank.
Quick Reply: twin pump issues..
