Twin walbro 400's in Fbody
Old 08-25-2013, 10:42 PM
Patsy57's Avatar
Default Twin walbro 400's in Fbody
Anyone running twin walbro 400's in an Fbody? I wanna run this setup and wanna see if anyone is and if you have a build thread. Please let me know
Thanks
Old 08-26-2013, 06:43 AM
Ollie8974's Avatar
Read the two sticky's at the top of this forum.
https://ls1tech.com/forums/fueling-i...ick-cheap.html
https://ls1tech.com/forums/fueling-i...tion-here.html
Old 08-26-2013, 06:55 AM
Patsy57's Avatar
Originally Posted by Ollie8974
yes read them, anyone do it with 400`s? Also i was told 400`s are overkill by one sponsor. I am going to be running a fully forged 427 LSX block, with Procharger F1R and COG kit. I want to ensure if i push it the fuel is there. so my question is dual 400`s or dual 340`s?
Old 08-26-2013, 08:22 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
You were told that for a few very good reasons...
First, they do not fit in a 99-02 bucket.
Second, running too much pump increases current draw & fuel heating... this is why you size your pumps for the actual demand. Why do this if you do not need it? Overkill is not a safety margin in this case, it is just creating more issues that you do not need.
Take a realistic look at your power goals & size accordingly.
Typically twin 255's are good for 1000rwhp & 340's for 1200, conservatively rated.
Old 08-26-2013, 08:29 AM
Patsy57's Avatar
Just covering my bases, so the upgraded ones should cover the power I'm gonna make and potentially make with the cog setup?
Old 08-26-2013, 09:20 AM
LS1TECH Sponsor
For a typical F1R build, you will likely not exceed 1100rwhp.
In that case, the twin 340's are all you need.
Personally unless you plan to push it to the max output, I would still consider the twin 255's. My builds have proven extremely reliable & street friendly with these pumps. I have had a few hit 1100rwhp on these, but it is admittedly at the limits.
Quick Reply: Twin walbro 400's in Fbody
