Need help with -8 feed and -6 return
What's the part number for the fitting yall are using to make the feed a -8 and what part are yall using to connect your return to your stock feed line because I am going to use it as my return line. And do yall use two hot wire kits when running twin in tank pumps? Second pump will be on a hobb switch
