raising fuel pressure
Hi just curious if anyone has raised base fuel pressure on a rising rate reg to fatten up the ratios a bit?
I am considering raising the base pressure slightly and hopefully it will fatten the ratio up through the whole range to give me a little more of a safety margin on my turbo stroker build. Car is already tuned and it is safe but would like to know if this is the effect I will get by doing it?
LS1TECH Sponsor
Yes you can, but keep in mind the pressure increase is exponential to the air fuel ratio change... meaning it takes a 9% pressure increase to make a 3% air fuel ratio change.
Also keep in mind the pump flow drops off sharply at high pressures, so you may run out of pump if you try raising the pressure too high.
Lonnies performance thanks for the info. BLown06 ha ha very funny. Yes I agree tuning is the best option and The tune I have is safe, I rechecked my dyno sheet and the a/f is around 11.4 so I am happy with that. just curious on things effecting the a/f ratio.
Anyway I will be adding a second pump in parallel later on is that going to effect the a/f with everything else being the same? Or is that dependant on whether my aeromotive reg can dump enough to keep the pressure under control?
