Fittings used for -8 feed and -6 return on bucket
Old 09-28-2013, 09:28 PM
rorric's Avatar
Default Fittings used for -8 feed and -6 return on bucket
Can any one tell me what fittings they used to make there fuel pump have a -8 fitting for feed And what fitting the used for there -6 fitting they used for return? I see they sell dual pump set up with the different feed and return AN fittings just need to know what they are thanks peeps ..
Old 09-29-2013, 03:56 AM
Burken01's Avatar
You can purchase a -8an or -6an bulkhead and drill out the old feed tube and add the bulkhead in its place..
Then run whatever size line you go with to your fuel rails..
That's what I'm doing
It's not cheap and only necessary when running big power 650+ is a good rule of thumb even though some people have taken the stock lines higher...
How much power do you plan on having?
Old 09-29-2013, 05:33 AM
Ollie8974's Avatar
Are these the fittings you are looking For?
They are Russell fittings, available in Blue or Black -6 or -8 size.
Most of the vendors offer them.
Attached Thumbnails Fittings used for -8 feed  and -6 return on bucket-new-style-screw-lock.jpg   Fittings used for -8 feed  and -6 return on bucket-step-1-russell-efi.jpg   Fittings used for -8 feed  and -6 return on bucket-step-2-russell-efi.jpg   Fittings used for -8 feed  and -6 return on bucket-step-3-russell-efi.jpg
Old 09-29-2013, 07:34 AM
rorric's Avatar
Thanks guys Google images found what I was looking for.
Quick Reply: Fittings used for -8 feed and -6 return on bucket
