Turbo fuel system setup questions
Old 11-04-2013, 09:00 AM
shafe816's Avatar
Default Turbo fuel system setup questions
Ok guys have a few questions about fueling/lines fittings etc. I'm looking to turbo my trans am. I'm going to run E-85 in it. I plan on running twin in tank walbro's, on 93 or 105LB injectors (don't have them yet). -8 AN feed, aeromotive regulator, stock line as a return.
My questions basically are these: What rails should I use? Fast? Ebay?
Where do I hook the -8an line to at the tank, considering I am using the stock line as a return?
Anyone have any fitting numbers?
Anyone have a write-up I could look over until I get back the the states and can actually dig into it?
Car is a 99 so it has the plastic tank. LQ powered.
Any help would be greatly appreciated!
Old 11-08-2013, 09:27 AM
toytech93's Avatar
Sounds like you need a double pumper kit.
http://www.lonniesperformance.com/doublepumpers.htm
Quick Reply: Turbo fuel system setup questions
