fuel rail fitting adapters
Okay so I have these fuel rails I got from a guy in my state for my boosted 5.3 setup. The rails appear to be 1/2 inch inlet rails but when I pulled the fittings out of the ends because I have to change the size I can't figure out what size that screws into the rail. It is smaller than -8 but larger than -6. I looks to be an orb type fitting but he had everything put together with teflon tape.......anyways. I need -10 feed and -10 return per magnafuels advise so what do you think these fitting sizes are? Thanks in advance.
Don't let the fact that some used Teflon tape throw you. I have seen a lot of people use Teflon tape on fittings that don't require it. They simply don't understand what is doing the sealing.
I have even seen the guys on Horse Power TV do this.
