Kenne Bell BAP blown fuse
Old 11-27-2013, 10:11 AM
2007V's Avatar
Default Kenne Bell BAP blown fuse
I just replaced my stock pump with a DW300 an it blew the 30A inline fuse to the BAP. I believe the BAP is a 40A unit but it came with a 30A fuse. I'm not sure about just installing a 40A fuse in there though.
Has anyone had this issue or similar? The BAP voltage was set to the max setting so I have lowered it but I want to make sure the 30A will live or if a 40A is safe or if I need to hotwire the entire thing. 2007 ls2 ctsv.
Thanks!
Old 12-02-2013, 11:14 PM
CarlC's Avatar
Though sold as a 40A unit, the peak capacity is 32A, nominal 20A. At 32A things get warm quickly. I'm going through the same thing trying to power a late model CTS-V fuel module.
Don't go larger on the fuse, the wiring and holder are not up to the task.
The dual 40A unit outputs cannot be tied together.
Quick Reply: Kenne Bell BAP blown fuse
