Racetronix fuel pump/hotwire install instructions????
Old 12-04-2013, 05:16 PM
deonls1's Avatar
Default Racetronix fuel pump/hotwire install instructions????
I recently purchased a ractronix fuel pump/ hotwire kit for my 2001 Camaro from a member here on the forum. The only thing he didn't have was the directions to install it. Does anyone have the instructions that can email them to me?
Thanks
Old 12-05-2013, 08:01 AM
Ollie8974's Avatar
Contact Racetronix, they should be able supply a copy.
Old 12-05-2013, 09:23 AM
deonls1's Avatar
I contacted them on here. They sent me a link to register for the racetronix forum. I tried registering, but I guess since I didn't buy the pump directly from them it's a problem to get registered. One of the admins pmed me and said he couldn't find me in their database for buying it from them. I explained that it was bout of tech, and all I need is directions. Haven't heard from them since.
Old 12-05-2013, 09:28 AM
babbage1109's Avatar
I might have mine at home. I'll look after work
Old 12-05-2013, 12:40 PM
deonls1's Avatar
Awesome let me know.
Old 12-05-2013, 09:29 PM
deonls1's Avatar
If anybody has them I'd greatly appreciate it if you can send them too me.
Old 12-06-2013, 11:43 AM
Burken01's Avatar
Run the 10 gauge fused power line from the alternator down the frame rail following the brake line/fuel line to the rear of the car..
The relay will mount to the left of the fuel pump, just find any bolt in that area and hook the relay bracket to one of them..
Then unplug the bulkhead connector, you'll see plugged into the floor pan.. Then plug your connector into it and the plug you removed will now plug Into the other pigtail harness ..
Then your done..
Make sure the ground wire is grounded
Old 12-06-2013, 12:02 PM
Burken01's Avatar
The first pic shows the little fuel line bracket, mount the relay in this spot..
Then the other pic is the bulkhead connectors in the rear floor pan..
My car is a 98 so the connector is a little different, this car shown is a 2000 z28..
Attached Thumbnails Racetronix fuel pump/hotwire  install instructions????-image-2288440404.jpg   Racetronix fuel pump/hotwire  install instructions????-image-3343844091.jpg
Old 12-06-2013, 12:19 PM
deonls1's Avatar
I really appreciate the write up. Can this be performed using the trap door method?
Old 12-06-2013, 12:21 PM
Burken01's Avatar
If you don't want to drop the tank to get to the pump then yes you need to cut a trap door..
Old 12-06-2013, 04:00 PM
deonls1's Avatar
Oh ok. I was just making sure I didn't have to drop the tank. I will be doing the trap door method. I'm gonna tackle the job this weekend. If I have any questions I'll post them up.
Thanks
Old 12-06-2013, 06:00 PM
deonls1's Avatar
Isn't there something that has to be pinned out on the factory harness?
I remember in a thread I read awhile back about ractronix including a paper clip for that reason.
Quick Reply: Racetronix fuel pump/hotwire install instructions????
