Mounted my FPR,is this ok?
Remove the pump Module from the tank. Push up on the spring clip,
Remove the regulator.
I am thinking the same thing. I would not Run it there way to much heat at the very least make a heat shield out of aluminum or better yet find another place to mount that it. or you could just drive with one hand on the wheel and the other on whatever your using for fire suppression.
