? About Racetronix 160lb Injectors
Old 01-03-2014, 03:01 PM
1hotrod's Avatar
Default ? About Racetronix 160lb Injectors
If you don't buy the matched set of 8 what is the factory tolerance on these injectors? If you buy them matched do they come with flow sheets?
Old 01-05-2014, 09:21 AM
CornFedLS's Avatar
from past experience if you don't buy flow matched sets they will be all over the place causing a rough idle and not very smooth drivability
Quick Reply: ? About Racetronix 160lb Injectors
