BBK fuel rails with 98 fbody fuel system
Old 01-06-2014, 11:41 AM
98Zheadsncam's Avatar
Default BBK fuel rails with 98 fbody fuel system
This should be a simple question, but I can't seem to find the answer via Google. Can I just throw these fuel rails on in place of my stock fuel rail? I don't see a "pulse damper" on any aftermarket setups, so are they just not needed? Also, my current fuel rail only has one inlet..so i don't understand how it could be "return style" as found on 98 fbodies, from what I've read.
I'm quite aware that the factory fuel rails are just fine for a heads/cam car, but I've had these BBK rails for a while, and I figured I'd throw them on anyway.
Thanks.
Old 01-06-2014, 04:35 PM
jrpimp00's Avatar
No F Bodies had returns style rails, only the vettes, the return is in the rear. Should be no problem to use these.
Old 01-07-2014, 06:25 AM
Cool, y cars only then...that makes sense. Thanks!
Quick Reply: BBK fuel rails with 98 fbody fuel system
