Fuel pressure sending unit
Old 03-18-2014, 11:26 PM
patternpilot's Avatar
Default Fuel pressure sending unit
I have a ProSport fuel gauge that has been going through pressure senders quite rapidly. I am looking for suggestions from those who have used these gauges with pressure sending units from other manufactures. I have requested sending unit specifications from ProSport to no avail in the hopes of cross referencing. Pressure sending unit is mounted on the fuel rail. If anyone here could help it would be appreciated.
Old 03-19-2014, 08:14 AM
Old Geezer's Avatar
The common transducers have 2 different voltage requirements...Usually either 5VDC, or 12VDC. [Also have varying pressure ranges]
Be sure they are powered w/the correct voltage.
Old 03-19-2014, 08:31 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
buy a different gauge...
Old 03-19-2014, 11:38 PM
Well, this is not helpful. There is nothing wrong with the gauge. It is the sending unit. There are lots of these types of sending units available if you know its specifications. My question was to see if anyone had done the research and found one that will work.
Old 03-20-2014, 07:36 PM
LS1TECH Sponsor
Actually it was...
Once you spend the money on a good sender & if you can get it calibrated somewhat accurately, you will then learn the gauge is no better than the sender you just replaced & need to buy one of them also.
Just cut your losses & get an Autometer gauge.
You will likely save money in the long run.
Old 03-21-2014, 05:52 AM
Old Geezer's Avatar
What Lonnie said^^^^^^^^ Autometer is all we install in our custom gauge panels. Have found over the yrs, that many other, less popular gauges didn't "pass muster". Hence, Autometer only.
Old 03-21-2014, 10:09 PM
I decided that the problem is that there is too much vibration for the sending unit mounted to the fuel rail. So I took your advice, ordered the Autometer and a braided hose to remote mount the sensor. This should be the solution to this problem. I'm just tired of dealing with it and because fuel pressure is so important to my build, it needs to be watched.
Old 03-22-2014, 06:40 AM
Old Geezer's Avatar
"I decided that the problem is that there is too much vibration for the sending unit mounted to the fuel rail".
I mounted mine on the Aeromotive FPR, w/ a 90* elbo. Works great.
Old 03-26-2014, 12:56 PM
Ferocity02's Avatar
I use an Autometer sending unit mounted directly to the stock fuel rail where the pressure relief valve was. It's wired into the EGR 5V/signal/ground wires so I can datalog the fuel pressure using the EGR signal through the PCM. Works like a charm.
Old 03-28-2014, 06:01 PM
bmax's Avatar
X2, that's the way I do it too.
Quick Reply: Fuel pressure sending unit
