Confused on injector size
Old 03-23-2014, 12:34 PM
sumnerslayer's Avatar
Default Confused on injector size
Hey guys, I'm trying to pick out a set of injectors for my engine. This is my 1st attempt at a injected engine so any help will be greatly appreciated. I have a 2004 LQ4, internals are stock, LS6 intake w/24# injectors, ported TB, screen less MAF, LT headers and straight pipes all in a 82 Camaro with the T56. After I get the engine running and make sure everything is sound I plan to add a cam this summer or fall. My question is will the 24# injectors feed this thing OK until I put a cam in it? Am I better off buying bigger injectors now? I haven't sent my ECM off to be tuned yet. Was waiting until I get the injectors figured out 1st and was planning on going with Frost for a tune unless somebody recommends another tuner. Thanks in advance for any help!!
Old 03-23-2014, 01:16 PM
Old Geezer's Avatar
Those injs will do just fine, until a cam is installed.
Once the cam is in, do some data logs, and see what duty cycles are running at, go from there.
Old 03-23-2014, 01:36 PM
Good to hear!! Thanks a bunch! Sounds like I'll be sending off my ECM tomorrow! Can't wait to hit the key!!
Old 03-23-2014, 04:56 PM
ZL1Killa's Avatar
that 6.0L engine is going to need something larger than 24# injectors.
it will run fine part throttle, but I really don't suggest running around hitting 6k rpm, as I'm betting the duty cycle/DEMAND for fuel will exceed those 24#ers
Old 03-23-2014, 06:14 PM
Even with no internal mods? Can anybody else chime in on this, I've only got a little more wiring to do and if I have to order injectors I'd wanna do it now. Also anybody chime in on best max rpm a stock bottom end on a LQ4 will hold and last at?
Old 03-24-2014, 03:31 PM
Burken01's Avatar
I'd get some 42 lb injectors, they will work now, after the cam, when you decide to do heads, and when you decide on a shot of nitrous lol
Or if you can score some 36 lb injectors for $150 used then that would work as well
Check the classifieds
Old 03-24-2014, 07:06 PM
redtan's Avatar
Internal mods are not what necessitates the fueling your engine needs. The cam and heads do because they are the ones dictating how much air goes into the engine and thus the fueling needed.
With just a cam, you can just go up to some #36.
Old 03-24-2014, 08:57 PM
Thanks guys, I picked up a set of Bosch 4 hole 36# on eBay, can anybody recomend a good o2 sensor for me? I hear there are some to stay away from as they don't last?
Old 03-28-2014, 06:26 PM
my406cid's Avatar
I just purchased a set of new ls9 injectors.are thes overkill for a n/a street lq9 with l92 heads and a .050 224/232 .620/.604 ported l92 11.0 2800 3.42?
Old 03-28-2014, 09:10 PM
ZL1Killa's Avatar
they will provide plenty of fuel for that...you may be in the lower duty cycle ranges. Those are 56# at 58psi... if you have an adjustable fuel pressure (regulator) I would suggest turning them down to 43.5psi. they would then be 48.8LB injectors
Old 03-28-2014, 09:30 PM
my406cid's Avatar
Thanks
Old 06-05-2014, 10:51 AM
Back again fellas, I'm expecting to get my ecm back soon and was curious with the 36# injectors and stock ls1 fuel pressure am I gonna need a regulator?
Old 06-05-2014, 11:45 AM
ZL1Killa's Avatar
You really just need injectors. 36# would work fine, as your fuel pressure should be 58psi.
I see you are putting a T56 and the Lq4 in an older car, what kind of fuel system are you making or what do you have? You will need a regulator to regulate your fuel pressure... I'm not sure on the details of you fuel system, if you are using a factory LS1/LQ4/ Firebird/CAmaro system/tank.
Old 06-05-2014, 01:04 PM
I have a 4th gen plastic tank with a LS1 fuel pump, the tank it a direct bolt in for my 3rd gen, also have a fuel filter with built in regulator so I'm assuming its 58psi, I am going to need a regulator? What kind of pressure will the engine need? Sorry this is my 1st FI build
Old 06-06-2014, 11:34 AM
Anybody? With the 36# injectors will 58 psi be to much?
Old 06-10-2014, 07:43 AM
ZL1Killa's Avatar
no it won't
Quick Reply: Confused on injector size
