fuel pump trap door lid 4th gen f-body
Old 04-09-2014, 07:40 PM
ericwilloughby's Avatar
Default fuel pump trap door lid 4th gen f-body
I searched. None were complete with measurements so...
Stop by Harbor Freight and get one of these. It's worth $30
Remove the rear speaker plastics and the cargo hold down brackets. Pull the carpet back.
All of these shots are taken from the t-top hole...The best landmark is this valley. Measure from 1.5-2" from the end of it. You are avoiding the tank vent because it touches the metal and will get cut if you go further.
Cut, you have about 1" clearance under the metal except where you will be crossing that valley. The wires touch it. Don't go anywhere near it until you cut the other 3 sides and lift it up to inspect.
Finish cutting.
Attached Thumbnails fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-1-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-2-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-3-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-4-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-5-.jpg
Old 04-09-2014, 07:47 PM
Disconnect wiring. Removing the hoses is easy. Remember, you don't want fuel pressure on these. All you have to do is pinch the clear plastic pieces and twist and pull the hose. The center one, just pinch and pull.
wd-40 the bucket locking device and tap around it with a punch. Pull the bucket out. Be careful with the level sender float.
Mine looked like this.
Attached Thumbnails fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-6-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-7-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-8-.jpg   fuel pump trap door lid 4th gen f-body-fuel-pump-trap-door-4th-gen-f-body-9-.jpg
Old 04-09-2014, 07:50 PM
I'll be putting one of the Walbro turbine pumps in this bucket without chopping it up this weekend. Will post that also.
Old 04-09-2014, 08:08 PM
ss performance's Avatar
Nice write up.
Is that really a bare wire?
Old 04-09-2014, 08:53 PM
Yeah. Melted all the way to the bulkhead plug. I ordered all new upgraded wiring all the way back to the alternator...relay...plugs...from racetronix. Harness was as much as the pump.
they say this is a common problem.
Old 04-10-2014, 05:33 PM
spydog's Avatar
How do you re seal after you cut the access panel?
Old 04-11-2014, 05:45 AM
spydog's Avatar
I looked I have a plastic tank. I do not have access to a cnc laser so what should a guy like me do also anyone have good measurements of the location to be cut out I am a newbie to this but I figure if my friend and I was able to install a monster cluch in my car I should be able to do this pump access hole
Old 04-11-2014, 08:34 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Thread cleaned up...keep it civil and on track please.
Old 04-11-2014, 09:02 PM
Thank you sir. I sealed my trap door up today. Used simple metal type duct tape. The door was resting on the excess wire from the hotwire kit so it didn't need any support under it. Easy, simple.
I fired it up without a regulator in the return line today and to my amazment it runs and is driveable with 20 psi of fuel pressure and a quick retune of the injector flow rate. Damn. That evap return has a rather restrictive 5/16ths hose barb. I may need to open that up so my regulator, that won't be here til next week, will meter properly. Will see.
Old 03-26-2018, 11:44 AM
Cthornsmax92's Avatar
Default Size
Know this is an old post, but getting ready to do my 00 SS and want to "Finish" the door off nicely, can you tell me the dimensions of the hole? Basically wanting to know if this would work size wise.
https://www.speedwaymotors.com/Fuel-...oor,60735.html
Old 03-27-2018, 12:37 AM
klinznilk's Avatar
Here is what I used for mine. It turned out great imo. A little tight getting it out however it works.
Amazon Amazon
Allstar Performance ALL18541 Access Panel Kit
Old 09-09-2022, 07:40 AM
OrgnDonr's Avatar
I was thinking of going this route as well. do you happen to have the dimensions you cut?
Old 09-09-2022, 09:09 AM
Received 3,019 Likes on 2,350 Posts
Who are you asking? This thread is 8 years old.
The following 2 users liked this post by G Atsma:
madmike9396 (09-09-2022), Mgill (10-07-2022)
Old 04-01-2023, 01:03 AM
ls1z01's Avatar
Just did the trap door and took some measurements for people who wants reference.
Old 04-01-2023, 08:54 AM
wannafbody's Avatar
Summit Racing sells a nice looking trap door plate kit.
Old 04-01-2023, 09:09 AM
01CamaroSSTx's Avatar
Received 1,785 Likes on 1,293 Posts
Did a hinged door with a little loop handle on mine and it's nice having the extra room to get at the connections.
The following users liked this post:
jmilz28 (12-22-2023)
Quick Reply: fuel pump trap door lid 4th gen f-body
