Economy Rails for LS1 intake that don't leak
Old 04-14-2014, 09:53 AM
agpatrick12's Avatar
Default Economy Rails for LS1 intake that don't leak
I have researched and seen mixed results which worries me.
I'm looking for a good set of economy aftermarket rails for an LS1 intake.
I'm going with 80lb injectors and it'll be a turbo lm7 with around 650whp.
Are the leaks and issues really just caused by install error??
Old 04-14-2014, 11:48 PM
Ford_Assassin's Avatar
In for replies....
Old 04-16-2014, 12:05 PM
munn79ta's Avatar
ive installed professional products fuel rails on my buddies car and after making some spacers for the bolts that go into the intake they sealed ok.
Old 04-17-2014, 11:50 PM
Hardcoresoldier's Avatar
I am using Holley billet rails. They are about $100-$150 cheaper than the competition and make brackets to fit any injector/intake combination. I am using LS1 injectors on my LS3 intake.
Old 04-18-2014, 10:04 AM
Pocket's Avatar
Used a half dozen sets of these without issue. Used rails are generally $50-80
Use pipe tape or sealer on the NPT fittings and dont over tighten them. Good to go
Old 05-01-2014, 08:20 AM
Thanks for the replies. I'll look into both the holley and PP.
Old 05-01-2014, 07:00 PM
Old Geezer's Avatar
What we're using.
Really nice finish, threads are smooth, made for o'ring fittings, not the nasty pipe threads, that look like Fido'sazz. Have center feed ports if you need them.
http://www.ebay.com/itm/290621370255?_trksid=p2059212.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Quick Reply: Economy Rails for LS1 intake that don't leak
