Ethanol free gasoline
Old 04-15-2014, 12:24 PM
Closed ex-Sponsor Account
AngelsTransport's Avatar
Default Ethanol free gasoline
My car is tuned on East Coast 93 octane that I am planning on moving to Cali which obviously doesn't have 93 octane, but I do have access to ethanol free 93 octane.
What difference does that make performance wise? All fuel now comes with a blend of 10% ethanol and 90% gasoline which affects your mpg versus a non ethanol blend, but I would figure you also lose cooling efficiencies with an ethanol free fuel because of the cooling properties of alcohol. Any thoughts on this?
Old 04-15-2014, 12:33 PM
Rise of the Phoenix's Avatar
You totally contradict yourself there. You either have access to 93 or you don't. Ethanol free 93 is better than 93 with ethanol. I only buy my 93 from the gas station that says their 93 is ethanol free.
Old 04-15-2014, 12:42 PM
Meaning you can't buy 93 octane at any pump in California, BUT there is a local fuel supplier that sells ethanol free 93 octane in drums.
Old 04-15-2014, 12:46 PM
I don't see a problem then if you have the means to buy 93 where you're moving to. Like I said, ethanol free is better than ethanol blend.
Old 04-15-2014, 01:03 PM
fengstang's Avatar
Just get a drum and fill it so you can filled it in your own garage.
Quick Reply: Ethanol free gasoline
