E85 Fuel System and Injector Help
Old 04-21-2014, 05:14 PM
jscherbs's Avatar
Default E85 Fuel System and Injector Help
Hey guys,
Coming from the Dmax world I'm new to this forum and the LS in general but I have a few questions about a potential fuel system Id like to run...
I currently have an 04 RCSB Silverado, set up is in my signature. I'm looking to convert this over to E85 and make around 1000+ rwhp. What injector would it take to accomplish this? I have heard good things about ID2000's as well as FIC2000's however I have been told these are not E85 injectors so the rail will need to be purged? Not sure how much validity there is to that... But then I have also been told that the FIC127's could make 1k Hp and they are designed for E85 so those would be more turn key.
Also I was told I would need to upgrade the pump that supplies the injectors. Would it be possible to use my existing Aeromotive 340 stealth pump to feed a pair of 044 Bosch pumps? I'm also not sure how big of a line to run.
Any insight on this one would be helpful, thanks in advance.
Old 04-21-2014, 05:38 PM
I need a gauge for that
Atomic's Avatar
1000rwhp on the corn? Dual 450s and 127s will get you there, but thats about it at 20psi of boost.
160s with dual 450s will get you about 1100rwhp.
Read this: http://www.performancetrucks.net/for...p-flow-510434/
Quick Reply: E85 Fuel System and Injector Help
