Injectors to big?
Injectors to big?
Hey guys, I have a stock LS3 with a Whipple 2.9 supercharger that makes a bunch of power and TQ and drives like a champ. It has a slight "hunt" at idle (100 rpm or less) and the guy that did the tuning said the duty cycle of the injectors is at 1% or less at idle and only 60% or so at WOT. Whipple sends new injectors (63 lb) with the supercharger as well as a MSD fuel pump booster that raises the voltage with engine RPM and it was not installed due to the fact that I have good fuel pressure and idle and WOT. SO.... Will to big of a fuel injector with a very small duty cycle at idle cause unstable rpm (hunt) at idle?
were the parameters changed for injectors in your tune? (all of them) and NOT JUST the IFR table
for instance, offset table, minimum pulsewidth, default pulse width...etc
