Fuel Pressure Adjustment Question
Old 04-26-2014, 10:11 PM
Shorty Director
VINCE's Avatar
Default Fuel Pressure Adjustment Question
In the process of going from 60lb injectors, boost referenced FPR, with return style fuel system, one bosch 340LPH and KB BAP to 80lb injectors, boost referenced FPR, with return style fuel system and two stealth 340LPH and KB BAP.
My question is do I simply make the fuel changes to HPT going from 60lbs to 80lbs or do I make adjustments to my FPR and change the injector scaling?
Thanks in advance.
Old 04-27-2014, 07:53 AM
Old Geezer's Avatar
"My question is do I simply make the fuel changes to HPT going from 60lbs to 80lbs or do I make adjustments to my FPR and change the injector scaling?"
The new pump setup may call for resetting the fp. [Check it]. Base should remain the same. [If the old and new injs are rated at the same psi.]
The tune will have to have the new inj constants, etc, entered.
Old 04-27-2014, 10:24 AM
Shorty Director
VINCE's Avatar
That makes sense. I will check to see if the base FP has changed and reset as necessary. I will also adjust the injector scaling.
Quick Reply: Fuel Pressure Adjustment Question
