Return fuel lines
Old 04-29-2014, 10:08 AM
dkiller2135's Avatar
Default Return fuel lines
Hey guys,
Ive got a project that is using an Ls1 with the LQ4 intake. The intake has the return line for the tank. I was planning on uning the MSD in line fuel pump with the regulator/ filter.
What are my options?
I would like to run only one line from the tank, since the Jet boat was set up for a carb and only has 1 line teed to 2 tanks.
How would this be plumbed?
Ive got an 1999 truck ECM for this project.
Old 04-29-2014, 10:31 AM
ryanleiker's Avatar
Originally Posted by dkiller2135
Hey guys,
Find a newer year truck fuel rail and bolt it on. That's how I did mine.
The newer ones (2004+ I think) were regulated in the tank so they don't require a return line from the rails. They'll bolt on, no problem. Check the classified... people are almost giving them away.
Old 04-29-2014, 11:02 AM
If I changed the fuel rail and used an inline pump with no return line, would the pump just deadhead into the lines?
Old 04-29-2014, 11:40 AM
ryanleiker's Avatar
Yes, your inline regulator will return to the tank and the fuel will just end at the injectors.
Quick Reply: Return fuel lines
