What size injectors do i need??
Old 05-06-2014, 11:21 AM
pewtered'Z's Avatar
Default What size injectors do i need??
IM in the process of my build and it's came to the point to buy fuel pump and injectors. 2000 z28, stock bottom end, ported 243 heads, tick polluter cam, fast 92/92, race tronics pump, 200 shot. Any clue on what size injectors I'll need for n/a and the 200 shot?
Old 05-06-2014, 11:22 AM
Rise of the Phoenix's Avatar
44lb/hr would be good, but if you're looking for room to grow, 60lb/hr would work too.
Old 05-06-2014, 11:30 AM
pewtered'Z's Avatar
So in the future if I wana do a bigger cubic inch motor or stroker motor 44lb would be to small?
Old 05-06-2014, 04:12 PM
If that's in your future plans, I personally would go with the 60lb/hr injectors. The 44lb/hr injectors would likely work, but would be at a much higher duty cycle. How big of a cubic inch motor are you thinking?
Old 05-07-2014, 11:20 AM
ZL1Killa's Avatar
42# @ 43.5psi pending your motor size, and I'm guessing wet setup on nitrous?
you will need a 255 pump for a set of 8 42#ers and if you go beyond that size, you will need dual 255 pumps or a secondary pump of some sort.
Old 05-07-2014, 12:27 PM
pewtered'Z's Avatar
Originally Posted by ZL1Killa
42# @ 43.5psi pending your motor size, and I'm guessing wet setup on nitrous? you will need a 255 pump for a set of 8 42#ers and if you go beyond that size, you will need dual 255 pumps or a secondary pump of some sort.
Yes dry kit, zex black out kit. I was planing on ordering race tronics fuel pump and hot wire kit.
Old 05-07-2014, 12:39 PM
Since it's a dry kit, I would go with the 60lb/hr injectors.
Old 05-07-2014, 08:38 PM
pewtered'Z's Avatar
I'm sorry wet kit.
Old 05-08-2014, 12:24 PM
Originally Posted by pewtered'Z
I'm sorry wet kit.
I would say try to find the best deal on either 44 or 60 lb/hr injectors in the classified section. Either will work fine as long ss the pump(s) are up to par.
Old 05-08-2014, 03:15 PM
pewtered'Z's Avatar
Will 42lb work? I see a few for sale now, I never really see 44, sometimes I see 46.
Old 05-08-2014, 07:14 PM
ZL1Killa's Avatar
yes. remember, your fuel pressure is 58psi, not 43.5psi. so at your fuel pressure they are 48# injectors. hope you are not confused
Old 05-09-2014, 12:28 PM
Good point. I would personally want to have enough injector to where I had room to grow in the future.
Quick Reply: What size injectors do i need??
