Racetronix Fuel Pump Question
Old 05-14-2014, 02:12 PM
camarols62002's Avatar
Default Racetronix Fuel Pump Question
I have a cam only 2002 camaro z28. i Was planning on a N/A build but have been looking into putting a small single turbo kit on instead. I do not want to push more than 600rwhp. Will my racetronix fuel pump with hotwire kit support that? they say its good for 600rwhp. i have been looking at the duel pump kits but it seems overkill for what i want. Any help or advice is appreciated
Old 05-14-2014, 07:20 PM
Mike 02T/A's Avatar
Look into one of the 340 LPH fuel pumps. They install the same way as the Racetronix pump. I was running Heads/Cam & 150 shot with the Racetronix pump with the hotwire kit, zero issues.
Old 05-14-2014, 07:22 PM
HCI2000SS's Avatar
I'm running a HCI 6.0 with a 100 shot and a Racetronix pump and hotwire as well, and have no issues either. At 600 rwhp I really think you need something a little bigger to be on the safe side
Old 05-15-2014, 12:57 PM
LS1TECH Sponsor
Racetronix's Avatar
Specs are listed in our web ad here:
http://www.racetronix.biz/itemdesc.a...A-001A&eq=&Tp=
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 05-15-2014, 06:40 PM
Thats what im running plus the hot wire kit. Im guessing with a turbo that it will support a little less than 600hp. I was just seeing if anyone has run a small turbo with 600hp or less just using this set up and bigger injectors of course.
Old 05-15-2014, 07:18 PM
Mike 02T/A's Avatar
I was running the same pump/hotwire kit and 60# SD injectors. Pressure dropped really quick until I switched out the fuel pump.
Look into a bigger pump or a dual setup. Save the money and only buy the parts once! My car made more power than expected and I'm needing more fuel pump and 80# injectors.
Old 05-15-2014, 07:25 PM
yea i think at this point its better safe then sorry. i will just switch to a duel pump set up. thanks for the advise guys
Quick Reply: Racetronix Fuel Pump Question
