How much injector?
Old 05-30-2014, 01:22 AM
wes96z's Avatar
Default How much injector?
Hey guys i have been searching on here trying to figure out what the largest injector i can use with my fuel set up. I have twin walboro, 255's in tank 8an feed 6an return and nasty performance rails I currently have 60lb injectors and im afraid they wont be enough for my HP goals of 800 on pump and possibly running e85 if im going to upgrade my injectors I only want to do it once and have room to grow. I know I may be limited by my fuel pumps but am looking for suggestions. Thanks.
Old 05-30-2014, 07:00 AM
Old Geezer's Avatar
https://ls1tech.com/forums/fueling-i...ump-chart.html
Old 05-30-2014, 10:15 AM
ZL1Killa's Avatar
pump to 85 is a good difference. you may not be able to only do it once
Old 06-01-2014, 03:26 PM
samdogmx's Avatar
for sure 60s wont be enough on E85. It could be done on gas with enough fuel pressure.
Old 06-01-2014, 07:47 PM
wes96z's Avatar
If I upgrade my injectors how big could I go with the dual walboro 255 before running into issues. Would the Siemens 83 lb injectors be a good fit?
Quick Reply: How much injector?
