wiring injector clips
I'm wiring in New injector clips and I need to know if it matters which way you wire them up. Can either wire be power or ground or are power and ground specific?
It does not matter which wire is power.
Make sure they are all wired the same.
I wired the power wire to the pin toward the back of the engine.
Splice the power wire between each cylinder, so there is only one power wire on each bank.
